1998 Ford Explorer clunking noise when I accelerate
216,000 MILES • V8 • AWD • AUTOMATIC
GARYS54
Oil is seeping from the front differential on the left side axle shaft and there's a clunking noise when I accelerate from a slow speed. Sounds like a gear is jumping over a broken tooth in the differential. Is it time for a new differential? Or could it be in the transfer case?
Jan 3, 2010 at 4:05 AM
  • 110,248 POSTS
If there is an axle seal leaking, it may just be a bad axle bearing. Have you checked them for play?
Jan 7, 2010 at 12:11 AM
GARYS54
The clunking sound is the worn chain in the transfer case jumping teeth when I accelerate. I removed the front driveshaft and can drive the vehicle until I can replace or rebuild the transfer case. The oil leak on the front differential is from the vent tube.
Jan 10, 2010 at 1:49 AM
  • 110,248 POSTS
I'm glad you found it. Let us know if you have questions in the future.
Jan 10, 2010 at 7:39 AM
  • 110,248 POSTS
I wanted to thank you for the positive feedback. Again, if you have questions in the future, let us know, and thanks for using 2carpros.com.
Jan 11, 2010 at 12:03 AM
