2002 Ford Explorer clunking noise when i first accelerate
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
ODINM
I have noticed a "clunking" noise when i first begin to drive after i have come to a stop. It almost sounds like a stick is stuck under the vehicle and is hitting an aluminum heat guard or something. The noise disappears as i increase speed. It sounds like the noise is coming from the rear drivers side but hard to be certain. Any ideas of what this could be? or what to check? I took off the rear passenger wheel but didn't see anything out of place, damaged or appear to be rubbing on anything. I did notice the wheel (prior to taking completely off) had some play, only an inch or so but a similar noise was heard when rotating (this could be normal??). Could it be a bad CV joint or could the rubber bushings inside the metal sleeves in the caliper?? I hate to drive on it if it is unsafe, please help asap.
Sep 12, 2009 at 12:57 AM
HMSTANG67
Is it a Clunking noise or banging and does it only happen once or twice after stopping every time? Please read 1997 Ford Explorer loud Banging noise on this site and left me know if this is what you are hearing and maybe we can solve this together. Thanks
Sep 26, 2009 at 8:47 AM
