1998 Ford Explorer AC Not Working When Standing Still
CGRANTANDERSON
  • 1998 FORD EXPLORER
  • 6 CYL
  • 140,000 MILES
The AC working when the car is moving but not when standing still. Freon levels are fine (full). Any ideas? Thanks!
Wednesday, July 30th, 2008 AT 8:55 PM
DOCHAGERTY
  • 9,603 POSTS
Does the auxiliary fan work? It is the fan in front of the A/C condenser that moves the air when you are stopped. It should run when you turn on the A/C.
Thursday, July 31st, 2008 AT 12:45 AM
CGRANTANDERSON
The Explorer does not have an auxiliary fan. But it should as the AC doesn't work that well without it (that is found on other more expensive models).
I took it to the dealer and they said that they replace the AC relay and did not charge me anything. I wasn't able to get a good answer from them on what they did but it is now working much better. Still having some difficulty handling the intense heat of Atlanta summers (90 - 100 degrees F) but I suspect that the design being without the auxiliary fan is what makes it not work very well when accelerating or standing still.
It is working much better though so I'll leave it at that.
Thanks!
Thursday, August 7th, 2008 AT 8:30 AM
Related Air Conditioner Not Working Content
