2000 Ford Explorer Vent blows hot air
156,000 MILES • 6 CYL • 2WD • AUTOMATIC
ZUKER
When the car is warmed up and the vent is turned on it blows out hot air as if the heater was turned on. Is there a valve/solenoid/thermostat that is not closing?
Apr 9, 2010 at 10:05 PM
  • 110,251 POSTS
I recommend having the blend door actuator checked. If it doesn't work properly, it will cause this problem.
Apr 12, 2010 at 12:17 AM
ZUKER
Thank you, that was it.
Apr 14, 2010 at 9:05 AM
  • 110,251 POSTS
I'm glad you got it taken care of. Let us know if you have questions in the future, and thank you for using 2carpros.com.
Apr 14, 2010 at 3:08 PM
