1997 Ford Explorer temperature adjustment
177,850 MILES • V8 • AWD • AUTOMATIC
WOOGLES
  • 6 POSTS
the ac works on max ac but on ac or any other setiing there is nothing but hot air. i change the temperature adjustment switch, same problem. When in Max AC position "plunger" on hot water hose is out when in any other position ac heat vent defrost plunger is in
Apr 26, 2010 at 11:49 AM
  • 110,248 POSTS
Hi:
When you use max AC, it is recirculating the air from in the car. This sounds like a problem with the blend door. Have you checked to make sure it is working?
Apr 26, 2010 at 3:40 PM
WOOGLES
  • 6 POSTS
[quote:0c46951ed2="Jacobandnickolas"]Hi:
When you use max AC, it is recirculating the air from in the car. This sounds like a problem with the blend door. Have you checked to make sure it is working?[/quote:0c46951ed2]
The function select switch works, air goes out def. floor vents, both etc. The valve on hot water line, that has a vacuum hose going to it, is in one position on max ac and on full in with all other functions. Is the blend door inside the dash? Is it possibly stuck? I guess my question is, does hot water flow regulate temp or air flow or a combonation of both? Thanks for your response!
Apr 26, 2010 at 11:57 PM
  • 110,248 POSTS
The blend door regulates the temp. In one direction it allows AC to enter. If it goes the other way, then heat enters. It is located under the dash near the heater core. (not a fun job).
Apr 27, 2010 at 5:15 AM
