1997 Ford Explorer Clanking Noise
SHOTGLASS63
I have a 1997 ford explorer sport 4x4 4.0 v6 160,000 miles a couple days ago it started making a "clanking" noise (sounds like someone hitting a pipe with another pipe) sounds like it's coming from the left front wheel but when we jacked it up it seems to be coming from farther under the front end. The noise is only there when the car starts moving. We checked the 4wd and it works fine. There aren't any vibrations almost sounds like something hitting when the driveshaft turns. Wondering if it might be the transfer case or really just looking for suggestions to what it might be?
Mar 4, 2007 at 9:10 AM
NOS
  • 320 POSTS
check the front drive shaft. the knuckle right by the transfercase is usualy the problem grab hold of it and shake it up and down. i think you will find your problem. but don't rule out a bad u-joint out at the front axels. 8) NOS
Mar 4, 2007 at 11:48 AM
SHOTGLASS63
Thank you so much. We will try this and let you know what we find.
Mar 4, 2007 at 12:47 PM
NOS
  • 320 POSTS
please don't forget to vote for me if you think i helped you. all input is excepted. 8) NOS
Mar 5, 2007 at 12:52 PM
Suggested Repair
Inspect the front driveshaft, especially the knuckle near the transfer case, by grabbing it and shaking it up and down. Also check the U-joints at the front axles.
Conversation Summary
The owner of a 1997 Ford Explorer Sport reports a clanking noise that starts when the vehicle moves and seems to come from the left front or farther under the front end, like something hitting as the driveshaft turns. Four-wheel drive works and there are no vibrations. The expert advises checking the front driveshaft knuckle by the transfer case and not ruling out a bad U-joint at the front axles.
