1997 Ford Explorer shakes real bad any time its moving
JUSTWANT2NO
  • 1997 FORD EXPLORER
  • 4 CYL
  • 4WD
  • 300,000 MILES
U can go any speed and it shakes real bad like it shakes the car so much it feels like it s going to fall apart. I took out the abs fuse and it stop and another thing it would stop after you drove it a couple miles down the road. But I think u need abs to get it inspected. Please help.
Monday, May 3rd, 2010 AT 2:51 AM
  • 109,885 POSTS
I'm not sure what state you are in, but in PA you don't need abs to pass inspection. As far as the vibration, did you only feel it when you used the brakes? As far as removing the fuse for the ABS, the brakes will still work fine, but you no longer have ABS.
Was the ABS light or check engine light on prior to removing the fuse?
Saturday, May 8th, 2010 AT 10:18 PM
