1997 Ford Explorer Rear wheels making noise
LORI_FDZ
  • 1997 FORD EXPLORER
  • V8
  • 4WD
  • 15,000 MILES
The rear wheels on my Ford Explorer make a cracking/crackling noise when I turn the car off after having driven it around. The sound is something similar to the crackling noise an old hot engine makes when its cooling off. The noise is definitely coming from the rear wheels, because I got close to them and could hear the noise. I also pushed on one of the tires and the noise seemed to stop for a couple of seconds, but then it came on again. After whatever is making the noise cools off, the noise stops. I did get new tires but that was almost two months ago so I'm not sure if this has something to do with it. The guy that put my new tires on told me that the breaks were fine. Can you please tell me what it could possibly be? I'm scared to drive the car around.
Wednesday, September 22nd, 2010 AT 3:43 PM
  • 109,874 POSTS
It could be the brakes cooling or the exhaust system. They both get hot when used and when cooling, they can make noise.
Wednesday, September 22nd, 2010 AT 11:32 PM
LORI_FDZ
Thank you for your response. Do you think that I should have the brakes or exhaust system checked? Is it something I should be concerned about? As I mentioned, I got new tires two months ago and the guy that put them on said the brakes were fine. Then again the car is old, its a 97, so I guess its supposed to make noise. Do you think its safe to drive the car with it making this noise?
Thank you again for all of your help.
Thursday, September 23rd, 2010 AT 12:55 PM
  • 109,874 POSTS
Sorry about the delay in responding to you. I lost a family member and things have been.
As far as the noise, I can't be 100% sure without being there. However, if you only hear it when it is turned off, I really believe it is the exhaust cooling.
Saturday, September 25th, 2010 AT 1:08 AM
