1997 Ford Explorer problems bleeding brakes
130,000 MILES • 6 CYL • 4WD • AUTOMATIC
SLOWE0524
I changed the rotors, brake calipers and brakes pads. When I started to bleed the brake lines I started from left to right and bleed them numerous times and got nothing but brake fluid everytime so i did the same with the rear from left to right and bleed the master cylinder nothing but fluid came out. Is there something that I am not doing or need to do different? Thanks.
Aug 16, 2008 at 1:44 AM
MERLIN2021
  • 17,250 POSTS
I'm just going to throw this out there, I have seen this once or twice, make sure the bleeders are on top! If you hang the calipers on the wrong side, the bleeders will be at the bottom, and air will NEVER be bled out! Bleed sequence is RR, LR, RF, LF.
Aug 16, 2008 at 1:48 AM
