1997 Ford Explorer ABS
72,000 MILES • 6 CYL • 4WD • AUTOMATIC
BRUCELAVERDIERE
No abs light on. When I come to a stop even on dry roads, just before the stop at like 1 mph the abs seems to kick on. Brakes work fine at higher speeds, its just when you are about stopped that it happens. replaced both hubs and a sensor. Any other ideas, is this typical? Thanks
Jan 30, 2010 at 2:31 AM
SCOTTY DEE
  • 592 POSTS
Just because the ABS light isn't on dosen't mean that there isn't code information in memory. Unless you're always stopping on gravel, no it's not normal.
Have the ABS module scanned for codes.
Jan 30, 2010 at 12:09 PM
