1997 Ford Explorer how to change the power steering oil
GIRAMUECA
  • 1997 FORD EXPLORER
Steering problem
1997 Ford Explorer 6 cyl Four Wheel Drive Automatic
how to change the power steering oil, and replace the cap?
The oil look like mud? What can I do?
Friday, September 24th, 2010 AT 7:01 AM
  • 109,885 POSTS
There are products that are out there for this purpose. Where I work, we have a machine that does it. To do it at home, lift the weight off the front of the vehicle. Vacuum the fluid from the pump and refill it. Start the engine and turn the steering from left stop to right stop about 5 times. Shut the engine, vacuum the fluid and do it again until all of the old fluid is removed and it is clean again. This will take several attempts, but will eventually clean things up for you.
As I mentioned, there are products that are designed for this. Check out the parts store and ask. Follow the directions provided if they differ from mine.
Saturday, September 25th, 2010 AT 12:54 AM
