1997 Ford Explorer Flashing 4 wheel dash lights flashing
WES WANGEN
  • 1997 FORD EXPLORER
  • V8
  • 4WD
  • 20,000 MILES
When I went to put my Ford in drive after backing out of a driveway I could feel the left front wheel grabbing and you could hear a groaning type of noise, it let loose but the four wheel drive lights dash lights flashed twice then clear, then after another 5 mins or so they flashed again repeating the senerio till I got back home.
Sunday, July 25th, 2010 AT 1:32 PM
  • 109,874 POSTS
It sounds like the actuator is bad on the transfer case. Does it shift in and out of 4wd?
Monday, July 26th, 2010 AT 1:02 AM
WES WANGEN
On Sunday it would not, didn't turn the 4WD or 4WL lights on either, but today when I took it to a place we are going to work on it, it shifted fine into both 4WD & 4WL once I was there. But on the drive it still felt like the front axles were engaged.
Monday, July 26th, 2010 AT 9:07 PM
  • 109,874 POSTS
It sounds like a bad actuator. The only thing I can suggest is when it happens again, check to see if there is power to the actuator. If there is and it won't shift, replace it. It really isn't an uncommon problem.
Tuesday, July 27th, 2010 AT 12:49 AM
