1993 Ford Explorer 4 by 4 button on dash board
RBORDEAU
  • 1993 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 25,000 MILES
4 by 4 button on dash board does not light up or engage 4 wheel drive when pushed.I checked all fuses and they where good.I was told to replace the shift motor on transfer case but I dont want to start buying parts because someone says to, and plus I dont know if it will fix it after I buy it.I purchased a manual and it doesnt say anything about the 4 by 4 switch or anything in trouble shooting. Is there a way I can test things to try to emlimanate buying a bunch of parts that are not broke. Thank you very much
Saturday, January 19th, 2008 AT 4:03 PM
T-MAN
  • 9 POSTS
Replacing the electronic transfer conrtol module will fix problem, but also can take motor apart and use electronic parts cleaner to clean brushes inside. About 4 hours work, 6 bucks cost. Or replace for around 400 bucks
Sunday, February 17th, 2008 AT 5:12 AM
