Hi Jimmy,
Is the check engine light showing while running the engine?
If no, you would need to run a diagnostic on all the components to find out which is not performing to specs.
As it is related to the ambient temp, I would suspect the Intake Air Temperatue sensor.
SPONSORED LINKS
Wednesday, July 9th, 2008 AT 9:54 AM
