1997 Ford Explorer Clutch Problem
1997 FORD EXPLORER
THE TUCK
Can someone out there help me with a problem I am having with my clutch. I have just replaced the clutch plate and cover plate. And now although its not slipping it is very hard to get in and out of gear. It did this to an extent before I replaced the parts and the problem hasn't been cured with the replacement. I have had it bled and the problem is slightly worse. Is the problem lightly to be the master cylinder or the slave cylinder??? The mechanic who bled the system says that the master cylinder is ok.
Is there any adjustment at the slave cylinder end??
Also does anyone know of a web site that I can use to get workshop manual information as well??
Thanks for any help that someone can give me, as already spent heaps of money on this problem, and I would like to see this problem solved.
Jan 13, 2006 at 7:45 AM
THE TUCK
Hi has anyone out their got an answer for my problem. Thanks
Jan 14, 2006 at 6:58 AM
DB554
  • 35 POSTS
please tell me you changed your throw out bearing when you were in there cause that is what it sounds like to me.
Jan 15, 2006 at 8:27 AM
THE TUCK
Hi db554, thanks for your reply much appreciate your help. Our mechanic checked out the bearing and said it was ok before I put it all back together. Any other suggestions at all, anyones help on this is always appreciated as eventually someone out there may come up with what is wrong with something I may have missed. Thanks The Tuck
Jan 15, 2006 at 9:06 AM
