Look for air leaks in the intake path. Leaking vacuum hoses and air ducts are the primary suspects. If no problem is found with air leaks, then the intake manifold gasket and upper intake are suspect. That engine has a plastic upper intake, and they have been known to crack.
SPONSORED LINKS
Wednesday, April 8th, 2009 AT 10:12 AM
