1997 Ford Explorer
1997 FORD EXPLORER
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
JR309308
  • 5 POSTS
i have a 97 explorer 2 wheel drive milage 160000. when i get to about 30 or 40 and try to speed up it shakes like the engine is clogged and about to fall out. had the tranny replaced, plug wires, belt and air filter. any advice would be great.
Jan 30, 2010 at 5:17 AM
SCOTTY DEE
  • 592 POSTS
Any trouble codes? What kind of shape are the tires in?
Jan 30, 2010 at 8:39 AM
JR309308
  • 5 POSTS
the tires are in pretty good shape. there was a test on it that said system running 2 lean. but when i get on it i can blow through it and it stops. i have no idea where to start.
Jan 30, 2010 at 9:10 AM
SCOTTY DEE
  • 592 POSTS
Okay. Lean would mean not enough fuel. I need to the trouble code to get you started. Or, if you have a fuel pressure gauge with a long enough line to allow you to tape the gauge to the windsheild, you could drive it and watch the pressure at 30-40 mph, or when it screws up.
Jan 30, 2010 at 9:18 AM
JR309308
  • 5 POSTS
i dont have the code # but what do u think might be causing this. the engine light is not on right now but it is still doing it.
Jan 30, 2010 at 10:18 AM
SCOTTY DEE
  • 592 POSTS
It's difficult to speculate without any PID data. Are you going to try the fuel pressure test?
Jan 30, 2010 at 10:26 AM
JR309308
  • 5 POSTS
say the pressure is bad and i know it is how would i fix that.
Jan 30, 2010 at 10:29 AM
SCOTTY DEE
  • 592 POSTS
If the fuel pressure was below spec., we would verify that the pump is getting power to it, and that would indicate a fuel pump problem. The key to making this work for you, is to try to prevent throwing parts at it and hoping for a fix.
There is a flow of diagnosis that has to be used in approaching problem solving. That is why the trouble code is so important.
Do you have or have access to a basic code reader?
Jan 30, 2010 at 10:49 AM
JR309308
  • 5 POSTS
but if the engine light is not on will it read a code. i will get a code reader if i have to. also thanks for the quick responses.
Jan 30, 2010 at 11:23 AM
SCOTTY DEE
  • 592 POSTS
Didn't you say it had a lean code? That's a code :)
Fuel pump failures and loss of power to fuel pumps hardly ever set codes. Thats where sperience comes in. Been dar, did dat.
Did you give me any feedback? Good or bad give feedback.
Jan 30, 2010 at 11:28 AM
