1994 Ford Explorer
1994 FORD EXPLORER
ROBIN MCGOWAN
94 Ford Explorer will only do about 10 mph on take off gradually builds speed. running sluggish. Drove it to store was running fine came out took off and it started slowing. Took 1 hr to make a 25 min. trip home. Have changed te fuel filter and air filter. Seems to be running worse. Help!
Jun 4, 2006 at 10:53 AM
KEITH128
may seem to obvious but try checking the air filter
Jun 4, 2006 at 9:21 PM
SYNCRAIT
  • 235 POSTS
what does it have for milage and what size engine is in it
Jun 5, 2006 at 6:26 AM
HEAVYDUTY
  • 60 POSTS
possible vacuum leak, check the vacuum tree on the rear drivers side of the upper intake manifold .check for missing caps or a hose that has pulled off-they get oil soaked and mushy
Jun 5, 2006 at 8:58 PM
