1997 Ford Explorer
120,000 MILES • 6 CYL • 4WD • AUTOMATIC
ANDREW SPENCER
I have read your answer to someone elsr regarding brake/ABS problems - I am getting something similar: when braking for say the last foot as I am coming to a stop I getting what I suppose you could call a hissing sound + the foot pedal pulsates, the ABS light does not come on. I have put a meter on the wheel sensors and when I rotate the wheel I the meter goes up and down, which to me would suggest they are working, I have not yet checked the PCM for brake faults but before I do that any suggestions?
Thanks.
Andrew from England.
Jul 18, 2009 at 6:20 AM
MERLIN2021
  • 17,250 POSTS
Usually turns out to be a bit of play in a wheel bearing.
Jul 18, 2009 at 11:22 PM
ANDREW SPENCER
[quote:3ff6173ed3="merlin2021"]Usually turns out to be a bit of play in a wheel bearing.[/quote:3ff6173ed3]
There is play/float on the rear R/H drive shaft, in and out about 1.5 - 2mm. Could this be the problem?
Jul 19, 2009 at 6:26 AM
MERLIN2021
  • 17,250 POSTS
If the reluctor(ring gear) is on the shaft, yes it could...
Jul 20, 2009 at 6:55 AM
