Turn the key to on, you should be able to hear the pump run for 2-3 secs, if you cant, remove the gas cap and have someone turn the key, wait 10 seconds between tries. If pump runs, test pressure with key on. Then try turning the key on and of 4 or 5 times then start it, does it start? If so, the pump may be going. Also pull the vacuum hose off the fuel regulator, it's on the fuel rail, is there any gas in there? If so replace the regulator.
SPONSORED LINKS
Saturday, January 26th, 2008 AT 12:45 PM
