2004 Ford Explorer fuel system
MRMSRBL
Engine Mechanical problem
2004 Ford Explorer 6 cyl Four Wheel Drive Automatic
where can I locate a fuel pressure and tempeture sensor, I cannot locate this part online and none of the auto parts stores have any listing for it
Nov 14, 2009 at 7:22 AM
  • 110,246 POSTS
The fuel pressure is a regulator at the end of the fuel rail. As far as the pressure, you need a fuel pressure gauge to place on the schrader valve on the fuel rail to get a reading. As far as the temp sensor, it should be on the intake near the thermostat housing.
Nov 17, 2009 at 7:38 AM
MRMSRBL
Maybe my question was to general
I Know what and where the part is located on the vehicle, I have already removed it
What I need to know is where I can purchace a replacement part
NAPA and Parts America do not have a listing for this part in their inventory
Is this a dealer only item and if so do I need to buy the whole fuel rail assembly
and by the way on a 2004 the regulator is at the end of the fuel rail
and the pressure and temp sensor is on the middle of the fuel rail
Nov 17, 2009 at 10:22 AM
