I believe the fuel float gauge is part of the pump assembly. When you replaced the pump, is it possible that you trapped the float at the bottom of the tank so it can't move and is showing empty. Also, was the wiring connector and wiring in good condition including the ground?
SPONSORED LINKS
Tuesday, November 17th, 2009 AT 3:28 PM
