1996 Ford Explorer
JOSIEMARIE16
  • 1996 FORD EXPLORER
Brakes problem
1996 Ford Explorer 4 cyl Four Wheel Drive Automatic 175k miles
Whenever I step on the Brakes while driving my front end shakes as well as the peddle. I figured I needed brakepads and routers. Well, when I got new ones I still had that problem. I have no Idea what is causing it.
Saturday, October 17th, 2009 AT 11:28 AM
  • 109,959 POSTS
Do you still feel a pulsation in the brake pedal? Is the steering wheel still shaking? Has the vibration changed at all since the work?
Monday, October 26th, 2009 AT 7:59 AM
LYNDON9
I have a 96 explorer with the same problem. My mechanic disconnect the sensor wires at each front wheel and it solved the vibration problem, but you will not have anti-lock brakeing in the front. What is happening is the 1 sensors are reding 2 different speeds so they try to compensate your braking giving you the vibration. $300 fix im told by my mechanic so I just had him disconnect the sensors. Also your ABS light on the dash will come on.
Wednesday, October 28th, 2009 AT 7:41 PM
RMS63080
I had the sme problem and my mechanic had to put a new wheel bearing with the ABS censor on and now breaks are fine
Monday, February 22nd, 2010 AT 12:06 AM
