1996 Ford Explorer
JWS_1992
  • 1996 FORD EXPLORER
1996 Ford Explorer 6 cyl Four Wheel Drive Automatic
where s a speed sensor located on a 1996 ford explorer?
Sunday, September 21st, 2008 AT 2:21 PM
MERLIN2021
  • 17,250 POSTS
Check VSS - Unplug Vehicle Speed Sensor (VSS) connector, threaded into transmission (2WD), or into transfer case (4WD). Measure resistance between sensor terminals. If resistance is 200-300 ohms, repair wiring between VSS and servo. If resistance is not 200-300 ohms, replace VSS.
Sunday, September 21st, 2008 AT 2:27 PM
