1995 Ford Explorer power door locks
GEOSMUENKEL
  • 1995 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 179,000 MILES
The lock solenoids on all doors keep cycling when they are locked, none of them will unlock electrically, I have to use the key to open the door and manually pull up each lock shaft for the cycling to stop. None of the door or key fob switches lock or unlock.
Friday, January 9th, 2009 AT 10:34 AM
2CARPRO JACK
  • 11,533 POSTS
Does it not stop cycling until they are all unlocked? Or can you isolate it to one solenoid being moved that makes it stop?
Friday, January 9th, 2009 AT 4:00 PM
GEOSMUENKEL
They wont stop cycling until all latches are up
Friday, January 9th, 2009 AT 5:59 PM
2CARPRO JACK
  • 11,533 POSTS
Sounds like it may be a problem with the GEM (Generic Electrnoc Module) or a relay (relays are above L/R wheel well of vehicle)Need to get to the relays and see if the GEM is triggering the relays with partial power Pink-Lt/Green wire
Friday, January 9th, 2009 AT 7:32 PM
GEOSMUENKEL
Thanks so much, I wouldn't have found that box up in there, just moving the unit and checking if the relays click fixed it! Geo.
Monday, January 12th, 2009 AT 10:19 AM
