1995 Ford Explorer fuel tank
170,000 MILES • 6 CYL • 4WD • AUTOMATIC
OSSOBO
How to remove the fuel on explorer 1995
Mar 25, 2009 at 8:14 PM
MERLIN2021
  • 17,250 POSTS
Only way I know is with a syphon, available at any parts store...
Mar 26, 2009 at 12:31 AM
OSSOBO
Thanks for this prompt reply, but my question was incomplete, I wanted to know how to remove the fuel tank on explorer 1995.
Mar 26, 2009 at 7:30 PM
MERLIN2021
  • 17,250 POSTS
Fords have two strap, first unplug the electrical connectors, and fuel lines, depresurize the system first, you can do that by the fuel rail by pushing the schraeder valve and releasing the prssure, use a rag to catch the gas, remove the clamp, if it has one on the filler neck remove the two straps, each one has t bolt, then lower the tank with a floor jack. Best to leave about one gallon or so in it if you are removing the pump.
Mar 27, 2009 at 12:16 AM
