1994 Ford Explorer No Reverse
FDPIERCE
I have a 1994 Ford Explorer with 155000 miles. After driving for about 30 minutes at 55mph I stopped at a store. The engine was off for about 10 minutes.
I shifted into reverse and the transmission would not engage into gear. It would shift into forward. So I put it into neutral and my son and I tried to push it backwards. it would not budge an inch. I checked the tranny fluid, it was at the proper level. I rubbed some between my fingers to check for grit, there was none. The fluid did not looked, smelled or tasted burnt.
I am an outboard machanic and I have seen my fair share of wierd things happen butthis was a first.
Lucky enough a man with a truck and a tow rope pulled in and dragged me back far enough to allow me to drive away. I drove it around the block about five times listening for any odd sounds. I did not hear any. Being over a hundred miles from home I did not have much of a choice but to head for home. i did not have any problems the whole way home. When I got home I tried putting it into reverse and it still will not engage.
So, now please tell me what can be wrong with it? I am thinking that it could use a good flushing out and a new filter screen. Any help you can give would be greatly appreciated.
Jun 7, 2007 at 6:43 PM
MERLIN2021
  • 17,250 POSTS
You have a pressure problem...it takes 2 times the pressure to go in reverse as in forward! I would install a new filter and fluid to see if that helps.
Jun 7, 2007 at 7:34 PM
TXSOUNDMAN
Went out today this morning and no reverse but vehicle moves freely in reverse one time i got it to engage but now it wont engage. any info? things to look for or questions to ask garage
thanks
Shawn
Jan 5, 2009 at 2:49 PM
Suggested Repair
Replace the transmission filter and fluid first. Reverse needs higher hydraulic pressure than forward, so a restricted filter or degraded fluid can prevent reverse engagement even when the fluid level looks normal.
Conversation Summary
A 1994 Ford Explorer with 155,000 miles would not engage reverse after a short stop, though forward gears still worked and the vehicle could not be pushed backward. The fluid level was correct and the fluid showed no grit or burnt smell. After being towed far enough to drive away, the Explorer drove home normally but still would not engage reverse. The expert attributed this to a hydraulic pressure problem, noting reverse requires about twice the pressure of forward, and recommended installing a new filter and fluid. A later update said reverse still usually would not engage, though it engaged once.
