1999 Ford Explorer Won't move forward and reverse
135,500 MILES • 6 CYL • 4WD • AUTOMATIC
ENDONAVY
I recently shifted into reverse and heard a loud knock form the rear of the SUV. The vehicle would not move in reverse or forward. I shifted from auto to 4WD low and it moved forward but will not go in reverse. I have not had the transmission serviced in about 2 years. any information would be greatly appreciated, to take with me to the shop. Thanks.
Jun 2, 2010 at 1:31 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like a trans issue.If it was drivetrain it should have still moved both directions in 4wd.If you put it in neutral can you roll it forward and rear? this iwll rule out the rear end
Jun 2, 2010 at 4:57 AM
ENDONAVY
I can push it forward and backwards, but i can't drive it in reverse. Thanks.
Jun 2, 2010 at 7:28 AM
2CARPRO JACK
  • 11,533 POSTS
Then it is most likely the trans that broke.Have a reputable trans shop look at it to verify this, but it may be time for a rebuild
Jun 2, 2010 at 9:44 AM
