I don't THINK so, it depends on a few things. I believe a 94 had a non-electronic transmission and Ford went to the electronic in 95. If they have the same engine and are both 4WD, you would just have to check and see if they are the same model transmission. I found this helpful when we looked for a replacement for mine:
http://www.charlietranny.com/Ford.htm
Hope that helps!
SPONSORED LINKS
Tuesday, September 21st, 2010 AT 11:30 PM
