Transmission swap
AHAMLET1991
  • 1994 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 225,000 MILES
Will the transmission out of a 91 ranger with a v6 2.9 fit into a 94 explorer with a v6 4.0?
Sunday, December 21st, 2008 AT 6:38 PM
JOHNH2009
  • 6 POSTS
No, however, 1991 to 1994 Explorer trans are swapable.
Monday, February 2nd, 2009 AT 1:03 PM
504CAM
  • 7 POSTS
I can drop a 93 explorer 2wd trans into a 94 4x4? I'm deleting the 4x4 transfer case completely. Should be fine right?
Friday, December 14th, 2018 AT 1:19 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 47,643 POSTS
Yep, you should be good. Here is a video that will help walk you through the job which is on a similar car:
https://youtu.be/3vJAojsrfuU
Cheers, Ken
Friday, December 14th, 2018 AT 1:38 PM
