Hi Mary
You may go through some more fuses, But the fact is something is causing this the eng control computer runs the vital control parts of the engine. So why not unplug eng control and see if fuse still blows. If yes then it is not the fuel system at all but possibly the ignition system as in distributor module coil.
Unplug these things one at a time. Lternator unplug also
i realize this is tedious and slow 'but believe me we have to do this the same way. Just a simple process of elimination. Try these and if none of it works write back I will see if we can figure it out
SPONSORED LINKS
Monday, September 27th, 2010 AT 5:37 PM
