My driver's side door has recently started to give me problems. The electrical is fine, and it opens fine, but when I go to close it, it bounces right back. The door seems to hang lower on its hinge and the only way to close it is to lift up on the handle and lift the door and inch or so to close it. Also, the spindle that the lock glides up on is 2/3s cracked off (the little rotating plastic piece on the knob) which also seems to be causing a problem in the closing of the door. What is that piece called and what would I have to go about doing to fix it? Thanks.
Monday, November 17th, 2008 AT 5:08 PM
