1999 Ford Explorer door locks not opreating propely
BOBGUZAK
  • 1999 FORD EXPLORER
Electrical problem
1999 Ford Explorer 6 cyl Four Wheel Drive Automatic
drivers door swicht will unlock but not lock doors
wires are fine anything else to check?
Thursday, June 25th, 2009 AT 11:52 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for the donation
This is fairly common on your model of vehicle. There is a barrel between the door and frame, where the wires run through, there is a bolt on top of the barrel. Loosen the bolt. The bottom part of the barrel will pull out eventually. (The bottom part is an electric conector) Pull down the rubber sleeve on the bottom part, and there you should see a broken wire, pink/green for unlock and pink/yellow for lock. If the wiring is broke, splice the broken wires together. Reattach the bottom part to the top and test operation.
Thursday, June 25th, 2009 AT 1:08 PM
BOBGUZAK
No wires are broken that I see. Is there something else it could be?
Thursday, June 25th, 2009 AT 3:27 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Is it only the driver's switch that is not operating the locks properly? Do the individual switches for the passengers lock and unlock properly?
Friday, June 26th, 2009 AT 2:41 PM
BOBGUZAK
Passenger side doesnt work locking or unlocking.
The back switch work fine I can lock and unlock.
My keyless entry doesnt work either
Saturday, June 27th, 2009 AT 10:37 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Ok, you will need to test the door lock relay. It is located in auxiliary relay box #2, above left rear wheelwell.
Saturday, June 27th, 2009 AT 11:28 AM
DANNYBLAZE
My driver's door and hatch locks don't stay locked, you can pull up the outside handle and they unlock but both back doors and passengers' doors stay locked. I've replaced the switch and actuators but still the same issue.
Monday, January 23rd, 2023 AT 12:58 PM
