The 4x4 touch button does not light and it doesn't seem to go into 4 wheel drive
Wednesday, December 17th, 2008 AT 1:02 PM
BOBO234
MEMBER
You will need to check the electric shift motor located on the rear of the transfer case for power and to make sure there is good connections at the plug. If there is, you may have a problem with a seized motor
SPONSORED LINKS
Friday, December 19th, 2008 AT 7:52 PM
RONJR913
MEMBER
I have 91' explorer and had the same problem and still have it every once in awhile my plug behind the button is a little loose and I have to take my dash apart and push the plug in a little further and it works.
