1992 Ford Explorer
MELISSA1992
  • 1992 FORD EXPLORER
  • 6 CYL
  • MANUAL
  • 75,000 MILES
We keep hearing a clanking noise coming from the engine, and while I was driving home from work last night the vehicle died and there was antifreeze leaking from the radiator. I got it started again but it only stayed started for about 30 seconds then died again. I also have been having problems with when I start it and try to drive it. It will chug for about 5 minutes and it does that alot when I am in 1st gear. Any suggestions would be greatly appreciated.
Wednesday, December 2nd, 2009 AT 1:46 PM
  • 109,896 POSTS
First, could you describe the sound? Also, are you sure the radiator is leaking or could it be the waterpump? THe water pump can make a clanking noise if it is bad, and it can leak coolant from a weep hole.
Now as far as the running problem. Did the engine ever over heat? If so, how badly? My concern is there is a possible headgasket problem.
LEt me know so I can better help you.
Wednesday, December 2nd, 2009 AT 10:19 PM
