2002 Ford Explorer No-Crank After Sitting
TAKODA123
We have a problem with the vehicle starting if it has set for over 10-12 hours. The last time we replaced the battery the cables were very badly corroded; the alternator checked out fine (took the cable off the battery and the vehicle continued running). This battery is three weeks old and will not turn the vehicle, once jumped it will run for a couple days - but then not turn over. Your help would be appreciated.
Jan 30, 2007 at 12:20 PM
2CARPRO JACK
  • 11,533 POSTS
First of all the pulling the cable off trick is a big no-no with computer controlled cars.Just because the alt is charging doesnt mean it isnt bad.Have the alt bench tested, could very well have a bad diode that is drawing the battery down while it is sitting
Jan 30, 2007 at 11:39 PM
Suggested Repair
Have the alternator bench tested for a bad diode that can drain the battery while the vehicle sits. Do not test charging by disconnecting a battery cable on this computer-controlled vehicle, and repair any corroded battery cables.
Conversation Summary
A 2002 Ford Explorer will not crank after sitting 10-12 hours. A three-week-old battery starts the vehicle after a jump, then fails again after a couple of days; battery cables were badly corroded when the previous battery was replaced. The owner checked the alternator by disconnecting a battery cable while the engine ran. The expert advised against that test and recommended a bench test because a bad diode can drain the battery while the vehicle sits.
