1995 Ford Explorer
TINOG24
  • 1995 FORD EXPLORER
Shakes or Wobbles problem
1995 Ford Explorer 6 cyl Four Wheel Drive Automatic
I recently changed wires and plugs on my explore and it statred spit and when you run it, it wont pick up speed as fast as it use to. Also it didn't do that befor I change them
Tuesday, June 15th, 2010 AT 4:07 PM
CARADIODOC
  • 33,916 POSTS
Hi tinog24. Welcome to the forum. This is typical of mixing up two or more spark plug wires and it happens to the best of us sooner or later. Look on the intake manifold for the firing order. The numbers are usually cast in somewhere visible.
Caradiodoc
Tuesday, June 15th, 2010 AT 4:29 PM
