2003 Ford Expedition Defrost Vents Only
TERRYSMITH
I have a 2003 Ford Expedition, 130,000 miles, 5.4liter. The a/c and heat work fine, but when I try to have it come out the front vents it does not blow. It will only blow out the defrost vents. What could the problem be?
Jun 5, 2007 at 2:17 PM
RUDPRO
  • 224 POSTS
I'm not an expert on your particular vehicle, but it could be the switch/control unit or a problem in the duct under the dashboard. There are flaps in the duct that operate to direct the airflow to the floor, defroster or vents. Some operate off of engine vacuum where a vacuum hose goes through the firewall to the duct and some operate off of small electric motor. Hope that helps a little.
Jun 6, 2007 at 12:05 PM
Suggested Repair
Inspect the HVAC mode switch or control unit and the airflow flaps in the under-dash duct. Check the vacuum hose through the firewall or the small electric actuator that moves those flaps between defrost, floor, and front vents.
Conversation Summary
The owner of a 2003 Ford Expedition with 130,000 miles says the A/C and heat work, but air will not come from the front vents and only blows from the defrost vents. The reply suggests a faulty mode switch or control unit, or stuck duct flaps operated by engine vacuum or a small electric motor.
