ABS sensors.
FORD EXPEDITION
BILL I. GALLANT
How many ABS sensors are there, and where are they located in a 1998 5.4L 2 wheel drive Ford Expedition.
I have an issue with the ABS kicking in when I hit the breaks and make a sharp left turn. Otherwise everything works fine. I've already changed a sensor that sits on top of the differential but still have the same problem.
Thanks in advance.
Aug 20, 2007 at 9:55 AM
SERVICE WRITER
  • 9,123 POSTS
Your bet bet is too start with the codes to find out the source wheel that is the problem. I "think" the sensors are part of the wheel hub/bearings on those.
Aug 20, 2007 at 9:58 AM
SERVICE WRITER
  • 9,123 POSTS
Oops! Your'e right Steve, the sensors do need to be monitored with a scanner when the problem happens.
Thanks for the correction.
Aug 20, 2007 at 10:17 PM
