1998 Ford Expedition antilock brakes intermittent
1998 FORD EXPEDITION
FARMER DAN
Brakes problem
1998 Ford Expedition V8 Four Wheel Drive Automatic ??? miles
when the front wheels are turned (like moving into a parking space) the brakes don't work. You can hear a loud clicking noise coming from the anti-lock brake system. Once the wheels are turned straight again the brakes work again. It's only 11 degrees here so I don't want to spend to much time laying in the snow trying to figure out what the problem is. Can I just pull the fuse out of the anti-lock system until the weather gets better?
Jan 12, 2010 at 10:50 PM
  • 110,244 POSTS
You can remove the fuse, but the ABS WILL NOT WORK. Chances are there is a build up of dirt / corrosion on the sensor causing it not to identify the wheel is moving when you are going slow.
Jan 18, 2010 at 6:26 AM
FARMER DAN
Ok I can go with that. Where is this sensor located and what do you recommend for cleaning it? Can I just use an air gun or do I need something like brake parts cleaner?
Jan 18, 2010 at 10:05 AM
