2008 Ford Expedition transmission grunts
40,000 MILES • V8 • 2WD • AUTOMATIC
HERBERT123
hi i have a strange grunt like pig that comes from i think the torque converter it only makes this noise if i put my foot down on the accelerator or more so if i put accelerator down on a hill ..its always been the same ,,someone said it maybe the limiter on the torque converter what do you think?
Dec 7, 2009 at 6:04 PM
  • 110,248 POSTS
Does the sound come from the trans? As far as a limiter, I question that. Have you checked the trans mount? Also, is the vehicle under factory warranty still? I believe it has a 60K powertrain warranty.
Let me know. However, make sure the trand mount is tight and not damaged.
LEt me know what you find, and thanks for using 2carpros.com.
Dec 19, 2009 at 3:56 PM
