2006 Ford Expedition Power steering
ALYROB
  • 2006 FORD EXPEDITION
  • V8
  • 34,000 MILES
The steering on the vehicle seems to be sluggish as well as choppy when turning the vehicle left or right. At first it came and went but now it appears to be happening all the time. The reservoir level is correct, the fluid still looks red but seems like it smells burnt.I suspect the steering pump or the rack and pinion assembly. Your input is appreciated!
Tuesday, July 14th, 2009 AT 5:07 PM
  • 109,885 POSTS
I would start by having the PS system flushed and all new fluid replaced. Also, I believe there is a steering gear in the vehicle not a rack and pinion, so that is one thing to eliminate.
Let me know what you find. Also, make sure the steering components are good including the ball joints.
Thursday, July 16th, 2009 AT 10:45 PM
ALYROB
A mechanic friend of mine also suggested a flush and to use Mercon V instead. Did it yesterday and so far it cured the problem. As for the steering application it is a rack and pinion setup. Thanks very much for your input! You offer excellent advice considering you can't see or hear the vehicle to evaluate the problem. Thanks again
Friday, July 17th, 2009 AT 10:13 AM
  • 109,885 POSTS
I'm glad that took care of the problem. I have the same vehicle (a year older) and it still has a steering gear. Sorry about that.
Take care, and let us know if you have questions in the future.
Thanks for using 2carpros. Com
Friday, July 17th, 2009 AT 3:38 PM
