2005 Ford Expedition OBD2 - P2196
2005 FORD EXPEDITION
100,536 MILES • V8 • 2WD • AUTOMATIC
METHOS126
got P2196 code
biased/stuck rich
bank 1/ sensor 1
I have white smoke coming from tailpipe
smoke smells rich
at first i thought O2 sensor , but the problem is too much fuel, and it is just sensing that.
injectors are good.
can the white smoke be from too much fuel, or is it coolant?
MAF? or pressure regulator?
Aug 6, 2010 at 8:19 AM
DOCFIXIT
  • 18,828 POSTS
Hi
More likely coolant from faulty headgasket. Over rich would be black smoke. White is coolant and has contaminated O2 giving reading.Pull plugs cylinder with leak will be super clean
Hope this helps
Thanks for donate
Aug 6, 2010 at 8:36 AM
