I believe the cover (trim) around the radio is either cliped into place or they use velcro. It should pull off, just be careful not to crack it. After it is off, there are two screws that hold the radio in place, remove them, slid the radio, unplug the wiring and antenna wire and it should come out. THe only other thing is some have a ground bolted onto the rear of the radio. You may have to unbolt that.
Let me know if this helps.
Oct 24, 2009 at 7:13 PM
