2003 Ford Expedition hvac air flow shifting between defrost
100,363 MILES • V8 • 4WD • AUTOMATIC
V8RUMBLE
Upon acceleration, blower door appears to shift from dash outlets to defrost postion, than returns when engine vacuum load is reduced. Could this be a vacuum hose loose or off, or more likely some type of valve or vacuum component? Thanks in advance for your help.
Jun 11, 2008 at 6:38 AM
JOYLER6883
V8rumble, did you figure out what was causing your problem? I am having the same issue on my 2002 Ford Expedition. Any help you can provide me on how to repair my truck would be great. Thanks
Sep 8, 2008 at 4:14 PM
