2001 Ford Expedition Fuel Pump
SSBEASLEY83
  • 2001 FORD EXPEDITION
  • V8
  • 4WD
  • 70,000 MILES
Where do I locate the fuel rail on a 2001 ford expedition 5.4l 8 cylinder to check my fuel pump with a guage?
Why truck shuts don when turning, cuttung on the ac and stopping at a light. What shouldi first do?I think its my fuel pump. Plus my gas seems to be working much harder then usely, useing more gas
Friday, August 6th, 2010 AT 12:03 PM
  • 109,885 POSTS
The fuel rail is on the top of the intake. Here is a how to that shows how to locate and check pressure.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Also, let me know if the check engine light has come on and if you checked for vacuum leaks.
Saturday, August 7th, 2010 AT 11:11 PM
SSBEASLEY83
  • 5 POSTS
Yes the engine check light stays on
Tuesday, August 10th, 2010 AT 12:17 PM
SSBEASLEY83
  • 5 POSTS
I would like to bring up my actuator on my power lock system. When I push unlock on my transmitter remote it only unlocks the driver door. The same when I try to manually unlock the doors it would only unlock he drivers door. What should I do sir?
Tuesday, August 10th, 2010 AT 9:05 PM
  • 109,885 POSTS
First, have the computer scanned to see why the check engine light is on. It will have trouble codes stored in it and most parts stores will scan it for free. Let me know what you find.
As far as the locks, is there anything you can do to make them all work? Have you checked the relay under the hood in the power distribution box?
Wednesday, August 11th, 2010 AT 12:09 AM
SSBEASLEY83
  • 5 POSTS
Yes I checked the fuse box under the hood with a fuse tester and its fine. And it won't work at all when I try to unlock the other doors. I had a check on the truck and it was a 2 bad coils which I changed, tear in belt and brake lite. But the light is still on.
Wednesday, August 11th, 2010 AT 7:50 AM
  • 109,885 POSTS
Have you checked the fuel pressure? Also, as far as the locks, if the driver's door lock works and the others don't, either the main switch on the door or there is a broken wire from from that swith to the others. It supplies the power.
Wednesday, August 11th, 2010 AT 9:33 PM
SSBEASLEY83
  • 5 POSTS
No I havent checked the fuel pressure but I will today. Thanks!
Thursday, August 12th, 2010 AT 7:11 AM
  • 109,885 POSTS
Let me know what you find. Here are directions for doing it.
Thursday, August 12th, 2010 AT 11:00 PM
