2000 Ford Expedition car wont start
SAMP21391
Engine Mechanical problem
2000 Ford Expedition V8 Four Wheel Drive Automatic
i have a 2000 ford expedition 5.4L and at first it would just crank but wouldnt actually turn on so i decided to change the fuel filter well turns out that it was clogged up but now when i try to start it it turns on for about 3 seconds then starts to die out as if there is no gas...there is gas in the truck so what else could it be?
Nov 10, 2009 at 8:04 AM
  • 110,248 POSTS
If the fuel filter helped, chances are it is fuel related. I would start by checking fuel pump pressure. Here is a how to for checking it.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
You will need a fuel gauge to check it. Most parts stores will lend or rent one to you.
Let me know what you find.
Nov 10, 2009 at 11:27 AM
