The automotive repair shop advised me that the following parts needed to be replaced or cleaned to correct the problem. I was advised that the gas tank needs to be flushed, the fuel rails needs to be replaced, the fuel filter needs to be replaced, the fuel pump needs to be replaced, the fuel injectors needs to be replaced and all seals/O-rings needed to be replaced.
My insurance appraiser states that all of the above needs to be done with the exception of replacing the fuel injectors. With a vehicle with this high mileage should the fuel injectors be cleaned & flushed or should they be replaced?
Also I would like to know if the fuel contamination problem can cause other mechanical related issues or problems?
SPONSORED LINKS
Friday, April 23rd, 2010 AT 4:42 PM
