1999 Ford Expedition Engine cranks will not start
RHDF150
  • 1999 FORD EXPEDITION
  • V8
  • 4WD
  • 109,000 MILES
This morning my truck wanted to startbut did not. After turning on the engine with the gas pedal half way down it started for a minute. As soon as I took my foot of the gas it died. I repeated the proccess again. After a half hour it started fine.
Thursday, October 7th, 2010 AT 12:24 PM
Next time it refuses to start don't wait for it to make up its mind-do below immediately to determine if its fuel or spark problem.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing.
Thursday, October 7th, 2010 AT 8:16 PM
