AIR VENTS ARE BLOWING HOT AIR, WHILE THE REAR AIR IS BLOWING COLD AIR. HOW DO I REPAIR?
Thursday, June 3rd, 2010 AT 5:34 PM
MECHANIC
I would say you have a problem with the blend air door. It determines if you get heat or AC. It is located near the heater core and will be either operated by vacuum or electric. Check that first. Something tells me it isn't closing.
